Is it possible to set mikrotik to be a DNS provider for VPN user but acting as primary DNS server for VPN user and forwarding queries to another DNS server in network but this DNS server isn’t available for VPN user (different network address / no routing between them).
VPN User 172.16.xx.xx → mikrotik 10.5.x.x (DNS resolver) → Primary DNS in that network 10.4.x.x
Yes because I can push DNS to VPN users or for LAN users. And also to prevent them of using another DNS I can redirect 53 in firewall / NAT. Ok it seems ok but..
allow request on and dns server set.
This CHR is also a DNS server for other mikrotik which is outside that network connected through GRE tunnel with IPSec.
So CHR has also 172.16.16.1/30 address and second mikrotik has 172.16.16.2/30
To make sure that CHR will forward queries I’ve set on CHR a DST-NAT with redirect on dst-port=53 to-port=53. So CHR will resolve queries by his own. I don’t want to use action=dst-nat and basically forward all request to 10.4.0.120 because if that hosts goes down VPN users from CHR will lose DNS service. The same goes for the second mikrotik (172.16.16.2) it also has redirect rule and in /ip dns
Sometimes it looses ability to resolve names from 10.5.0.120
put [:resolve iodine]
failure: dns name does not exist
I can’t figure it out
And I also found that when I add new entrie in DNS server (PowerDNS on Linux) the mikrotik doesn’t know what is the new host IP. After flushing cache it works.. It’s pointless
