I have an issue with HEX S after upgrading its firmware to 7.2.1 version. I setup an OpenVPN client on this router, and before the upgrade it worked pretty well and stable. Now the connection is not being established. Router sends a push request, OpenVPN server responds, and the connection resets from the router side.
Here is the extract from OpenVPN server logs:
PUSH: Received control message: ‘PUSH_REQUEST’
SENT CONTROL [mikrotik]: ‘PUSH_REPLY,route-gateway 10.8.0.1,topology subnet,ping 10,ping-restart 120,ifconfig 10.8.0.20 255.255.255.0’ (status=1)
Connection reset, restarting [0]
SIGUSR1[soft,connection-reset] received, client-instance restarting
TCP/UDP: Closing socket
All other vpn clients work well with this OpenVPN server. The server runs on Ubuntu, its version is 2.4.7.
Could you please advise me how to fix the issue?
