Hey,
I have set up a Ubuntu Server as OpenVPN Server. Issued Certificates, copied them to a Windows client, installed OpenVPN Windows Client software, configured, working nice. So the Server Configuration should be ok.
Now I wanted to add an OVPN Client Interface to my Mikrotik router using this configuration:
/interface ovpn-client
add name=“ovpn-out1” connect-to=w.x.y.z port=1194 mode=ip user=“username” password=“password” profile=default
certificate=cert1 cipher=aes256 add-default-route=no
I have copied and imported the same certificated and keys I used on the windows machine.
Yes, I can ping the OpenVPN Server IP.
No, windows client and MT Router never tried to connect at the same time.
There is no error report but the MT Log says:
17:43:20 ovpn,info ovpn-out1: terminating…
17:43:20 ovpn,info ovpn-out1: disconnected
17:43:20 ovpn,info ovpn-out1: initializing…
17:43:20 ovpn,info ovpn-out1: dialing…
17:43:21 ovpn,info ovpn-out1: initializing…
On the Server in ’ /var/log/syslog’ I see nothing that indicated connection requests from the MT Router, only from the Windows Client.
Any idea?
