Mikrotik as OpenVPN client
I have Mikrotik in my office. At home I’m running Asus, which is OpenVPN server. There is public static IPv4.
I was able to import ovpn config to Mikrotik and it looks connected:
My office network created by Mikrotik is 192.168.88.x and home network is 192.168.50.0. Routing table on Mikrotik:
Problem is ping from Mikrotik to 192.168.50.1 (or any other device in my home newtwork) ends with timeout. I’m trying it from Mikrotik > Tools > Ping.
Maybe I need to setup firewall on Mikrotik somehow? Can somebody help me with it please? Thanks
Maybe you should allow port 1194?
add chain=input protocol=udp dst-port=1194 action=accept
Try to ping Mikrotik from Asus and allow icmp input. Does it work?
If it does, then problem is a firewall on the Asus.
I am pretty sure you must open firewall on Asus and configure routing there
https://www.asus.com/support/faq/1013630/
