PC - local LAN address (192.168.1.0/24)
Ether2 - local LAN address
Ether1 - public static IP address (work as DHCP client, but always gets same IP address from internet provider)
Situation is very simple, but I can’t figure it out. I have enabled PPTP server on my RB750, entered secrets, profile and so one. When I try to dial up VPN connection from my local LAN (from PC) to Ether2 IP address, everything is OK.
But VPN won’t work from “outside”, from my home for example, to Ether1 port (public IP address).
I have tried everything, reset to default settings, changed RouterOS version…nothing.
Yes, but remember to also permit GRE. PPTP’s control channel is tcp/1723, the data channel is GRE.
Alternatively allow tcp/1723 and traffic with a connection-state of ‘related’, but then you are at the mercy of the helper that classifies the data channel as such with some amount of increase of security as you’re not permitting rogue GRE traffic that could potentially (but rather unlikely) be malicious.
