I find myself struggling with setting up my Mikrotik as a road warrior wireguard client.
The config which I get from the server does work on my phone and laptop, but I’d like to configure this straight in my Mikrotik router
Site A (client):
Mikrotik LTE dish (RBLHGGR)
WAN: super floaty, behind ISP NAT, terrible but nothing we can do about it
LAN: IP and subnet: 192.168.188.1/24
Desire: act as a Wireguard client to the Wireguard server set up at site B
Site B (server):
Ubiquiti Unifi UDM
IP and subnet of LAN: 10.103.14.1/24
WAN IP: fixed 12.34.56.78 (<== I’ll replace my actual IP everywhere to this one to make it as easy as possible)
[Interface]
PrivateKey = <private key Y>
Address = 192.168.2.2/32
DNS = 192.168.2.1
[Peer]
PublicKey = <public key Z>
AllowedIPs = 192.168.2.0/24, 10.103.14.0/24
Endpoint = 12.34.56.78:51820
(this exact same config works on my phone when imported into the app)
(I also added Y and Z, just in case in the future we find ourselves needing to copy/post more then one public/private key value)
As you see the UDM has seperate subnet for wireguard clients, basically assigning the Mikrotik one IP for the tunnel and thus (assumption on my side) we probably need to play around with NAT.
What did I do so far: lots of research, found some interesting topics on this forum as well, but got my main inspiration from https://forum.mikrotik.com/viewtopic.php?t=182340 adapting for the part mentioning third pary VPNs (which I belief I can consider my UDM to be).
Last but not least my Mikrotik config. Basically I have only made changes to the default configuration as the default config does serve my purpose very well.
# 2023-12-21 14:52:34 by RouterOS 7.13
# software id = **ELIDED**
# model = RBLHGGR
# serial number = **ELIDED**
/interface lte
set [ find default-name=lte1 ] allow-roaming=no band=""
/interface wireguard
add listen-port=51820 mtu=1420 name=wireguard1
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip hotspot profile
add name=default-dhcp ranges=192.168.188.10-192.168.188.254
add address-pool=default-dhcp interface=ether1 lease-time=10m name=defconf
/port
set 0 name=serial0
add comment=defconf interface=ether1 list=LAN
add comment=defconf interface=lte1 list=WAN
/interface wireguard peers
add allowed-address=10.103.14.0/24,192.168.2.0/24 endpoint-address=\
12.34.56.78 endpoint-port=51820 interface=wireguard1 public-key=\
"<public key Z>"
add address=192.168.188.1/24 comment=defconf interface=ether1 network=\
192.168.188.0
add address=192.168.2.2/24 interface=wireguard1 network=192.168.2.0
add address=192.168.188.0/24 comment=defconf dns-server=192.168.188.1 \
gateway=192.168.188.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.188.1 comment=defconf name=router.lan
add action=accept chain=forward out-interface=wireguard1 src-address=\
192.168.188.0/24
add action=accept chain=forward dst-address=12.34.56.78 in-interface=\
wireguard1
add action=accept chain=forward in-interface=wireguard1 out-interface=lte1
add action=accept chain=forward dst-address=10.103.14.0/24 src-address=\
192.168.188.0/24
add action=accept chain=forward dst-address=192.168.188.0/24 src-address=\
10.103.14.0/24
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
add action=masquerade chain=srcnat out-interface=wireguard1
add disabled=yes distance=1 dst-address=10.103.14.0/24 gateway=wireguard1 \
pref-src="" routing-table=main scope=30 suppress-hw-offload=no \
target-scope=10
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/system clock
set time-zone-name=Europe/Warsaw
/system note
set show-at-login=no
/tool mac-server
/tool mac-server mac-winbox
My goal: be able to reach the UDM and other things in site B by devices on site A and vice versa.
Issue: i see packages going out, but not returning and have no idea where i should look to solve this.
