Mikrotik as vpn client
Hi. I would like to set up Mikrotik to connect with a VPN server so that all users connected to Mikrotik will be automatically connected to this VPN. I have managed to set up PPTP client and Winbox shows that it is connected but when checking my public IP address it still shows the local WAN address. I also checked via whatismyip.com website and it still reports the local WAN address not the one related to my VPN. Thanks
Please share the Config Details Here so that we can understand the issue better.
Thanks :slight_smile:
Sorry for the delay. This is my configuration:
/caps-man channel
add band=2ghz-onlyn control-channel-width=20mhz frequency=2462 name=channel1
add name=bridge1
set [ find default-name=ether1 ] name=ether1-WAN
/interface pptp-client
add connect-to=vpnserver name=VPN-NAME password=xxxxx user=xxxxx
/caps-man datapath
add bridge=bridge1 name=Bridge
/caps-man security
add authentication-types=wpa2-psk,wpa2-eap encryption=aes-ccm name=security1 \
    passphrase=xxxxxxx
/caps-man configuration
add channel=channel1 country=malta datapath=Bridge mode=ap name=Config \
    security=security1 ssid=home
add name=WAN
add include=all name=LAN
set [ find default=yes ] authentication-types=wpa2-psk eap-methods="" mode=\
    dynamic-keys supplicant-identity=MikroTik wpa2-pre-shared-key=\
    xxxxxxx
/ip firewall layer7-protocol
add name=Facebook regexp="^.+(facebook).*\$"
add name=Youtube regexp=\
    "^.+(youtube.com | googlevideo.com | akamaihd.net).*\$"
/ip hotspot profile
/ip kid-control
add disabled=yes fri=0s-1h mon=0s-1h name="Block Now" sat=0s-1h sun=0s-1h \
    thu=0s-1h tue=0s-1h wed=0s-1h
add name=dhcp_pool ranges=192.168.2.100-192.168.2.200
add address-pool=dhcp_pool disabled=no interface=bridge1 name=dhcp3
/user group
set full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,pas\
    sword,web,sniff,sensitive,api,romon,dude,tikapp"
/caps-man manager
set enabled=yes
/caps-man manager interface
set [ find default=yes ] forbid=yes
add disabled=no interface=bridge1
/caps-man provisioning
add action=create-dynamic-enabled master-configuration=Config
set discover-interface-list=all
/interface detect-internet
set detect-interface-list=all internet-interface-list=all lan-interface-list=\
    all wan-interface-list=all
add interface=ether1-WAN list=WAN
add interface=ether2 list=LAN
add list=LAN
add address=192.168.2.1/24 interface=bridge1 network=192.168.2.0
/ip dhcp-client
add disabled=no interface=ether1-WAN
/ip dhcp-server lease
add address=192.168.2.0/24 dns-server=208.67.222.222,208.67.220.220 gateway=\
    192.168.2.1 netmask=24
set allow-remote-requests=yes
/ip firewall address-list
add address=0.0.0.0/8 comment="Self-Identification [RFC 3330]" list=Bogons
add address=10.0.0.0/8 comment="Private[RFC 1918] - CLASS A # Check if you nee\
    d this subnet before enable it" list=Bogons
add address=127.0.0.0/8 comment="Loopback [RFC 3330]" list=Bogons
add address=169.254.0.0/16 comment="Link Local [RFC 3330]" list=Bogons
add address=172.16.0.0/12 comment="Private[RFC 1918] - CLASS B # Check if you \
    need this subnet before enable it" list=Bogons
add address=192.0.2.0/24 comment="Reserved - IANA - TestNet1" list=Bogons
add address=192.88.99.0/24 comment="6to4 Relay Anycast [RFC 3068]" list=\
    Bogons
add address=198.18.0.0/15 comment="NIDB Testing" list=Bogons
add address=198.51.100.0/24 comment="Reserved - IANA - TestNet2" list=Bogons
add address=203.0.113.0/24 comment="Reserved - IANA - TestNet3" list=Bogons
add address=224.0.0.0/4 comment=\
    "MC, Class D, IANA # Check if you need this subnet before enable it" \
    list=Bogons
add address=192.168.2.101 list=VPN
add action=accept chain=forward comment="defconf: accept established,related" \
    connection-state=invalid
add action=drop chain=forward comment="Facebook drop example (What to drop mus\
    t appear first before the accept)" disabled=yes layer7-protocol=Facebook \
    port=80,443 protocol=tcp
add action=drop chain=forward comment="Youtube drop" disabled=yes \
    dst-address-list="Block youtube"
add action=drop chain=forward comment="Roblox port drop" disabled=yes \
    dst-port=49152-65535 protocol=udp
add action=drop chain=forward comment="Tiktok drop" disabled=yes \
    dst-address-list="Block tiktok" log-prefix=tk protocol=tcp
add action=accept chain=input port=69 protocol=udp
add action=accept chain=forward port=69 protocol=udp
add action=drop chain=input comment="DNS from outside drop UDP" dst-port=53 \
    in-interface=ether1-WAN protocol=udp
add action=drop chain=input comment="DNS from outside drop TCP" dst-port=53 \
    in-interface=ether1-WAN protocol=tcp
    "defconf:  drop all from WAN not DSTNATed" connection-nat-state=!dstnat \
    connection-state=new in-interface=ether1-WAN
add action=drop chain=forward comment="Drop to bogon list" dst-address-list=\
    Bogons
add action=accept chain=input comment="Allow ping" dst-limit=\
    30,30,dst-address/1m40s limit=30,30:packet protocol=icmp
add action=accept chain=input comment="Accept established" connection-state=\
    established
add action=accept chain=input comment="Accept related" connection-state=\
    related
add action=drop chain=input comment="Drop the rest" in-interface=ether1-WAN
add action=fasttrack-connection chain=forward comment="Fasttrack DNS TCP" \
    dst-port=53 protocol=tcp
add action=fasttrack-connection chain=forward comment="Fasttrack DNS UDP" \
    dst-port=53 protocol=udp
/ip firewall mangle
add action=mark-connection chain=prerouting comment=\
    "Facebook -created automatically Layer 7" connection-mark=no-mark \
    dst-port=53 layer7-protocol=*1 new-connection-mark=youtube_conn \
    passthrough=yes protocol=udp
add action=mark-routing chain=prerouting dst-address-list=VPN \
    new-routing-mark=vpn
add action=redirect chain=dstnat comment="Proxy redirect" disabled=yes \
    dst-port=80 protocol=tcp to-ports=8080
# VPN-NAME not ready
add action=masquerade chain=srcnat out-interface=VPN-NAME
add action=masquerade chain=srcnat comment=Masquerade ipsec-policy=out,none \
    out-interface-list=WAN
add action=dst-nat chain=dstnat dst-port=53 log=yes log-prefix=elt protocol=\
    udp src-address=192.168.2.200 to-addresses=8.8.8.8 to-ports=53
add action=dst-nat chain=dstnat dst-port=53 protocol=tcp src-address=\
add action=redirect chain=dstnat comment="proxy dns" disabled=yes dst-port=53 \
    protocol=tcp to-ports=53
    protocol=udp to-ports=53
/ip kid-control device
/ip proxy
set cache-administrator=xxx@gmail.com cache-on-disk=yes cache-path=\
    disk1/webproxy
add distance=1 gateway=VPN-NAME routing-mark=vpn
/ip service
set telnet disabled=yes
set ftp disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/ip ssh
set allow-none-crypto=yes forwarding-enabled=remote
/ip upnp
set enabled=yes
/system clock
set time-zone-name=Europe/Malta
/system watchdog
set watchdog-timer=no
/tool bandwidth-server
set enabled=no
I only require IP address 192.168.2.101 to connect to VPN automatically. Thanks
I think that the VPN mangle is wrong, it isn t dst address list VPN but scr address list. Try to set scr-address list to the VPN list.
