Mikrotik Asterisk
I just setup our first mikrotik router.. I setup basic load balancing for dual wan.
I wanted to use it as the gateway for our existing asterisk server.
Asterisk 192.168.1.2
LAN 192.168.1.2
We’re having issue with the call. I can do an outbound and inbound call. But sometimes when I try calling it doesn’t give me a ring, line 2 just answers. Also if I call toll free with IVR, it doesn’t connects to an extension..
Any suggestions?
Firewall nat:
0 chain=srcnat action=masquerade out-interface=WAN1 log=no log-pref
1 chain=srcnat action=masquerade out-interface=WAN2 log=no log-pref
Most likely issue when trying to load balance voice is that you’ve registered with a SIP peer from one WAN but then the load balancing sends a subsequent connection [signalling or media] out of another IP. Try turning off the load balancing first and see if it’s the load balancing or the NAT that’s breaking your voice.
