mikrotik attack?
i open a new terminal. i see a list of critical login failures.
is this some kind of attack? see below
jan/17/2011 08:27:51 system,error,critical login failure for user root from 140.52.115.30 via ssh
jan/17/2011 08:27:55 system,error,critical login failure for user root from 140.52.115.30 via ssh
jan/17/2011 08:28:00 system,error,critical login failure for user root from 140.52.115.30 via ssh
jan/17/2011 08:28:03 system,error,critical login failure for user root from 140.52.115.30 via ssh
jan/17/2011 08:28:12 system,error,critical login failure for user root from 140.52.115.30 via ssh
jan/17/2011 08:28:17 system,error,critical login failure for user root from 140.52.115.30 via ssh
jan/17/2011 08:28:20 system,error,critical login failure for user oracle from 140.52.115.30 via ssh
jan/17/2011 08:28:24 system,error,critical login failure for user test from 140.52.115.30 via ssh
ssh bruteforce attack, close ssh port or use firewall or change port number
This is a good solution against this attack:
http://wiki.mikrotik.com/wiki/Bruteforce_login_prevention
thanks…
thanks…normis
