mikrotik Audience placement
Hi all,
I’m planning to buy one, it is meant to be standing on the desk, however, if I put it closer to the ceiling (leave it on the small shelf made for it) will that improve the coverage in general or there is no point?
Thank you
It depends on the local obstructions.
Normally it will make no difference, but when this change makes it rise above some large metal obstruction (like a metal filing cabinet) it could make a difference.
