Mikrotik Audience
I have a customer who wants a more powerful router, so I thought of using an Audience. Unfortunately I can only get 20 mbs wirelessly. Wired and I can get the full input out. Somewhere between 250 and 300 mbs. KI did try resetting it to nothing and just configuring a basic wireless AP and can still only get 20Mb out.
Does anyone have any idea if this will put out more than 20mb on the wireless?
Hi Hoov,
This is the wireless configuration running on my Audience; by no means it’s the ideal one since I’m not a network professional and this setup is based on what I’ve managed to “steal” as information from this community. this setup runs ok on a daily use with 25+ devices.
# dec/29/2020 06:36:38 by RouterOS 6.48
# software id = XK81-DGB7
# model = RBD25G-5HPacQD2HPnD
# serial number = BB0C0A314402
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-g/n channel-width=20/40mhz-Ce country="united states" disabled=no installation=indoor keepalive-frames=disabled \
    mode=ap-bridge multicast-helper=disabled ssid=Beta wireless-protocol=802.11 wmm-support=enabled
set [ find default-name=wlan2 ] amsdu-limit=2048 antenna-gain=3 band=5ghz-n/ac channel-width=20/40/80mhz-eCee country="united states" disabled=no distance=\
    indoors frequency=5200 hw-protection-mode=rts-cts installation=indoor keepalive-frames=disabled mode=ap-bridge multicast-helper=disabled ssid=Beta_5G \
    station-roaming=enabled wireless-protocol=802.11 wmm-support=enabled wps-mode=push-button-virtual-only
set [ find default-name=wlan3 ] amsdu-limit=2048 band=5ghz-n/ac basic-rates-a/g=12Mbps,24Mbps channel-width=20/40/80/160mhz-eeeeCeee country="united states" \
    disabled=no distance=indoors frequency=5580 installation=indoor keepalive-frames=disabled mode=ap-bridge multicast-buffering=disabled multicast-helper=\
    disabled rate-set=configured ssid=Beta_5G_2 supported-rates-a/g=12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps vht-basic-mcs="" vht-supported-mcs=\
    mcs0-9,mcs0-9,mcs0-9,mcs0-9 wireless-protocol=802.11 wmm-support=enabled wps-mode=push-button-virtual-only
Your configuration intentionally limits the speed by a lot. Why did you decide to apply this found config? Your problem will most likely resolved by a simple reset to factory defaults.
