I own a AX2 for quite a long time, 1+ year. For all this time I had no issues with the wifi connectivity at all (maybe I used only the 5Ghz though, not sure :/). This changed the last couple of days with a strange issue. The issue that I suddenly have now is that my MacBook Pro 2023 (MacOs 14.6) can only connect to the wifi 2.4Ghz of my AX2 once. If it tries to reconnect it will always fail with either “cannot join network” or it will just ask for password every single time.
I think that the main reason that this happens is that the macbook somehow manages to save the connection as WPA3 personal even though when it asks for the wifi password it specifically states that this is WPA2 personal password.
I have tried multiple different configurations that I found in the forrums here (like this one) or in the internet without success.
My AX2 runs on version: 7.22.2 stable and this is my config:
I experimented with many of these options, for example I heard that ft/ft-over-dns can cause issues so I disabled it. I also disabled the steering rrm and/or wnm at some point. I tried editing multiple different combinations of these configurations without any success.
I am aware that this might not be a Mikrotik issue exactly, since my Linux/Android/iOs devices can connect without issues but if someone had a similar issues and have any tips I would be really grateful
I connected through SSH and run the commands that you said, plus I set the band from ssh:
/interface/wifi
set 2 channel.band=2ghz-n
Again 2 is the ID of of 2.4ghz wifi interface
Out of curiosity, you said that this is a bug in winbox 3? So if I used only the command line to configure everything it should have been fine all this time?
PS: The macbook still shows the network as WPA3 personal even though it is a WPA2 network and even though now it works as expected
I had 2 APs, one a cAP XL ac and the other a hAP ax3 on the basement. On the first floor, even though the signal to the basement ax device was around 84db, my work laptop wanted to connect to it because it provided wpa3 against the wpa2 of the ac device which provided a signal of 48db. It stuck with the wpa3 instead of the signal quality. Dunno if you have a similar setup. But could be worth a check
You disable g and ax (and "a" and "ac" if set like on 5GHz) when you set "only" n
You must set nothing for work with g/n/a/ac/ax on both interfaces (obv. "a" and "ac" on 5GHz only)
"b" is not supported.
/interface wifi
set [find] !channel.band
not, it's your typo, in export is ft-over-ds, but no problem, is a joke.
It's not normal for "mac-address" and "radio-mac" to appear unless you've done a "export verbose", or you have changed original MACs.
I recommend always doing a normal "export", so the default parameters aren't listed.
Yes and no.
Winbox 3 on 7.22 creates this artifact: interworking.realms-raw=""
and this artifact ONLY.
That setting prevents IOS devices (and evidently MacOS ones, as it happened to you) to connect/authenticate.
But the other mis-configurations are not coming from the use of WInbox 3, very likely you made them while attempting to troubleshoot the issue.
I hope that you're aware that these numbers are not constant, they are created dynamically by print command and are only valid until another print (can be in different config subtree) gets executed.
Correct way would be to run set [ find name="wifi2" ] channel.band=2ghz-n .
And again: the best practice is to unsetsecurity.managment-protection property altogether (don't set it to "disabled" or "allowed" or "required"), default (which then depends on actual security algorithm used by station, e.g. wpa2 or wpa3) is most of times just fine.
I know got what you guys talk about, I did a silly typo indeed.
Interesting, I just print the interfaces with detail:
[admin@MikroTik] /interface/wifi> print detail
Oh right! Now it makes much more sense what happens! Thanks!
Well no, I thought that these are permanent ids actually! So its really nice that you shared the correct way to do that, thanks
As for the management-protection it makes sense what you said, after all all this time it worked without any selection.
Thanks a ton for all the people that replied here, not only I fixed my issue but I learned a bit more about the configuration of my AX2 which is great!
