Mikrotik Back-It-Up Updated v3.0.0.1
HI
Mikrotik Back-It-Up is the best solution to make backups of your Routerboards. The Software is easy to use and all routerboad login data is stored on a local Database. The Software allows you to make single backups or multiple Backups, the backups is then exported in .backup & .rsc or .rsc(compact) format. The Backup Scheduler allows you to setup mutiple Group schedules for daily, weekly or monthly backups.
-Securely (SSH,SFTP) backup the settings of ALL of your Mikrotik devices
-Backup .backup, .rsc or .rsc(compact) you choose.
-Schedule automatic backups based on your settings daily, weekly or Monthly
-Allocate Sites, Clients to Groups.
-Backup all or just one of your devices, you select the Groups to Backup.
-Upload script & execute to single or multiple RouterBOARDS.
-Send command line to single or multiple RouterBOARD.
-Backup RouterBOARD Info with the New Export Tool.
-With the report tool, all backup logs are mailed to you.
-Tested with RouterOS v5.x & v6.x
http://www.mikrotikbackup.com/
Wish I googled your product earlier . I wrote some bash scripts to backup all our routers to a central NAS/SAN server daily but this looks much better than my bash shell mess hah.
Can I run it in the background?
Krisz
Yep All Schedules runs in the background. :smiley:
The website (http://www.mikrotikbackup.com/) is excruciatingly slow. Please re-up the image to a image hosting site?
UPDATE: Website is fast again. Must’ve been connection issues or server maintenance.
