I need your help, I am trying to create a backup file on mikrotik, but it always fail to create a backup can you help me please?
/system backup save name=([/system identity get name]"_"[/system clock get date]"log")
Format should be Hostname_MonthDaybackup.backup. For example Mikrotik_1205Log.backup
Can you help me please? Thank you.
I believe the issue is your
If you look at the output through the “put” command, it will print something like “nov/19/2018”
Herein lies the issue as you can’t have “/” in your name.
karlisi
November 20, 2018, 8:10am
3
Something like this?
:local filename;
:local date [/system clock get date];
:local name [/system identity get name];
:local months ("jan","feb","mar","apr","may","jun","jul","aug","sep","oct","nov","dec");
:local varMonth [:pick $date 0 3];
:set varMonth ([ :find $months $varMonth -1 ] + 1);
:if ($varMonth < 10) do={ :set varMonth ("0" . $varMonth); }
:local varDay [:pick $date 4 6];
:set filename ($name. "_" .$varMonth.$varDay);
/system backup save name=$filename;
Jotne
November 20, 2018, 8:28am
4
I would have added Year
:local filename;
:local varYear [:pick $date 7 11];
:set filename ($name. "_" .$varYear.$varMonth.$varDay);
karlisi
November 20, 2018, 12:00pm
5
It wasn’t in OP requirements
