Hi all,
Does anybody know if Mikrotik 5.17 support band steering ?
thanks in advance
Hi all,
thanks in advance
Yes, it doesn’t.
I posted this as a request as well…
http://forum.mikrotik.com/t/feature-request-client-band-select/60614/1
Has anyone tried doing this with scripting?
Say for example, every time a device connects to the 5Ghz interface, add an access list rule that denies it from authenticating with the 2Ghz interface. Unfortunately, amongst other side effects, I suspect that this would result in every connection dropping every time the access-list is updated - it would be better if you could add mac addresses to a list, then apply rules against said list.
So any updates to this any word. Unifi is about to roll out with there version of it.
you have reason maybe scripting can do the task… i dont have a dual band ap to try
