mikrotik bandwidth test - stopping after few hours
Hello, there!
I have done test of connection between two mikrotiks rb2011-rb2011.
Due to cpu limitations, it was tcp, 50M, one direction test.
Test was started ok, cpu usage reach 100% level, but traffic monitored at eth interface is going stable on 50M level.
10M level of one direction, tcp traffic uses 100% cpu usage, too.
Problem is, that test is stopping after 5-6h of working with no log info.
I have connected my snmp web server to show graphically test (MRTG).
Uptime of both MTs is ~few days, this is not uptime or reboot or power supply problem.
Have you any idea, why it stops with no reason? Should work up to my stopping command :frowning:
Rgds
Butchesky
Try using UDP.
Maybe the CPU didnt had enough resource to send tcp acks so the tcp session was dropped.
Though thats just my opinion though.
hth
no not use bandwith-test for prolonged tests. Use traffic-generator instead.
Ok, I’ll try traffic-generator.
Thank you for your help,
Rgds
Butchesky
