Hi, Mikrotik Tech and Admins,
Can the mikrotik basebox be as simultaneous dual band AP? eg. 2.4ghz as AP and 5ghz as backhaul simultaneously.
Regards,
Gabby
Regards,
Gabby
yes, if you put one 2,4GHz radio module and the 2 required pigtails inside the basebox5
(or 5GHz radio module and the 2 required pigtails inside basebox2)
Thanks rextended,
Thats gr8 about basebox. I will give it a try
Regards,
Gabby
I am using a BaseBox 5 and have added in a 2.4 GHz radio interface card. I’m using 5 dBi gain antennas and everything is working great.
1W power for both 5 GHz and 2 GHz in a single enclosure with PoE is attractive.
I test repeatly the authentication of my tablet and in my freeradius DB does not appear the MAC addresd of my tablet.
In the previous post, we attach one Accounting packet for the wireless accounting.
I think it is necessary to depuerate the accouting request that MT device sends to RADIUS server. It works fine for the hotspot service.
Unlock the key of your success by 300-115 and testking.By using our latest a+ certification and study material, you can easily pass kumc Your Exams.
