I have problem with my basebox. When i plug him directly to poe it work normaly, but when I plug poe into any switch or router basebox turn off and signal light on poe start blinking. It happening even switch/router is turned on or off.
I tried:
Change poe 100/ giga
change power adapter, voltage
cable
switch/router
antena but it also happening without antena
Both the 112 and the netpower can use either the ‘high’ or ‘low’ range of PoE voltage but the basebox will only support:
PoE in: Passive PoE(mod b or pins 4-5 + 7-8 return)
PoE in input Voltage: 8-30 V
can you please let us know what PoE voltage the devices you are plugging the base box into are as well as what your PoE budget is and how much of it is already spent?
Hello Aiden,
Thanks for your reply!
Now I understand the functioning of Basebox…
I am trying to plug the Basebox5 into my Netpower 16P with low voltage mode (Netpower 16P is already powering mantbox19s, netmetal and Powerbeam AC with low voltage setting)… I guess I can power the Basebox5 using the provided POE Adapter only…
