Mikrotik Basic Setup PPPoE to modem RB751
Hi All,
I have spent about 12 hours on this and have to finally call in some assistance.
I have the following setup
  1. Modem in bridged mode
  2. Mikrotik RB751
  3. Lots o computers on my LAN and wireless network
  4. An ISP I dial out from modem on.
I am wanting to share this internet connection to all machines through both ether1 and wlan1.
What I have working so far
  1. Microtik is successfully dialing and connecting to ISP
  2. DCHP server is working and handing out IP addresses (and the correct gateway afaik)
  3. Wireless clients work in the same way and get IP addresses
What is not working
  1. Any computer issued with an IP address is not able to use the WAN(internet)
  2. I can however ping machines on the WAN
  3. I cannot nslookup anything
  4. I cannot nslookup anything even when I force the machines to use 8.8.8.8 as the dns server.
What I suspect is my firewall rules.
I have restarted from scratch about 5 times and followed both these guides
http://wiki.mikrotik.com/wiki/How_to_Connect_your_Home_Network_to_xDSL_Line (This one killed access to the mikrotik and required reset to default)
http://wiki.mikrotik.com/wiki/A_script_to_set_up_WAN/LAN/WLAN_to_get_you_started (This one got me to where I am now but still not working)
If there is something wrong with these guides they should probably be removed from the wiki.
Below is my config and stats
[admin@MikroTik] > interface pppoe-client monitor pppoe-out1
        status: connected
        uptime: 15m46s
     idle-time: 1s
  active-links: 1
  service-name:
       ac-name: bne-pipe-bng1
        ac-mac: 00:30:88:17:47:08
           mtu: 1480
           mru: 1480
[admin@MikroTik] > /interface print
 #     NAME        TYPE               MTU L2MTU  MAX-L2MTU
 0     wlan1        wlan              1500  2290
 1  R  ether1-gateway        ether             1500  1600       4076
 2  R  ether2-master-local        ether             1500  1598       2028
 3     ether3-slave-local        ether             1500  1598       2028
 4     ether4-slave-local        ether             1500  1598       2028
 5     ether5-slave-local        ether             1500  1598       2028
 6  R  bridge-local        bridge            1500  1598
 7  R  pppoe-out1        pppoe-out         1480
ether2 and wlan1 are both bridged to bridge-local
ether3 -ether5 are all linked as slaves to ether2 (came like this as default not sure where setting is)
[admin@MikroTik] > /ip address print detail
 0   ;;; added by setup
     address=192.168.64.1/24 network=192.168.64.0 interface=bridge-local actual-interface=bridge-local
 1   address=192.168.64.2/24 network=192.168.64.0 interface=ether2-master-local actual-interface=bridge-local
 2 D address=124.171.233.51/32 network=203.215.9.250 interface=pppoe-out1 actual-interface=pppoe-out1
[admin@MikroTik] > /ip route print detail
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme, B - blackhole, U - unreachable, P - prohibit
 0 A S  ;;; added by setup
        dst-address=0.0.0.0/0 gateway=192.168.64.254 gateway-status=192.168.64.254 reachable bridge-local distance=1 scope=30 target-scope=10
 1  DS  dst-address=0.0.0.0/0 gateway=203.215.9.250 gateway-status=203.215.9.250 reachable pppoe-out1 distance=1 scope=30 target-scope=10
 2 ADC  dst-address=192.168.64.0/24 pref-src=192.168.64.1 gateway=bridge-local gateway-status=bridge-local reachable distance=0 scope=10
 3 ADC  dst-address=203.215.9.250/32 pref-src=124.171.233.51 gateway=pppoe-out1 gateway-status=pppoe-out1 reachable distance=0 scope=10
[admin@MikroTik] > /ip firewall export
# jan/02/1970 00:36:14 by RouterOS 5.7
# software id = 38RB-JCRU
set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s tcp-close-wait-timeout=10s tcp-established-timeout=1d tcp-fin-wait-timeout=10s \
    tcp-last-ack-timeout=10s tcp-syn-received-timeout=5s tcp-syn-sent-timeout=5s tcp-syncookie=no tcp-time-wait-timeout=10s udp-stream-timeout=3m \
    udp-timeout=10s
add action=accept chain=input comment="Local access to RB for Winbox" disabled=no dst-port=8291 protocol=tcp src-address-list=local
add action=accept chain=input comment=eLAN disabled=no in-interface=ether2-master-local
add action=accept chain=input comment=wLAN disabled=no in-interface=wlan1
add action=accept chain=input comment=bridge disabled=no in-interface=bridge-local
add action=jump chain=input comment="Treat all traffic equally" disabled=no jump-target=inbound
add action=jump chain=forward comment="Treat  all  traffic  equally" disabled=no jump-target=inbound
add action=accept chain=inbound comment="Allow limited icmp" disabled=no limit=50,5 protocol=icmp
add action=drop chain=inbound comment="Drop excess icmp" disabled=no protocol=icmp
add action=accept chain=inbound comment="Accept established" connection-state=established disabled=no
add action=accept chain=inbound comment="Accept related" connection-state=related disabled=no
add action=accept chain=inbound comment="Internal traffic can do what it wants." disabled=no src-address-list=local
add action=drop chain=inbound comment="And drop everything else" disabled=no
add action=accept chain=output comment="Allow everything out" disabled=no
add action=masquerade chain=srcnat disabled=no src-address=192.168.64.0/24
add action=masquerade chain=srcnat comment=NAT disabled=no out-interface=ether1-gateway
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=69
set irc disabled=no ports=6667
set h323 disabled=no
set sip disabled=no ports=5060,5061 sip-direct-media=yes
set pptp disabled=no
Any help would be greatly appreciated.
Edit: Added more information about dns
[admin@MikroTik] > ip dns print
                servers: 8.8.8.8,8.8.4.4
  allow-remote-requests: yes
    max-udp-packet-size: 512
             cache-size: 2048KiB
          cache-max-ttl: 1w
             cache-used: 10KiB
Ok worked out I forgot this line
/ip firewall address-list add address=“192.168.64.0/24” comment=“LAN” disabled=no list=local
Works now… whew
