Hallo,
I have troubles getting my Mikrotik Routerboard to work on a VDSL2 Magenta 100 connection from t-online.
I configured the speedport smart 2 telco router as modem only then i connected my RouterBoard on Port 1 to the “speedport smart 2” router on port 4.
I removed port ether1 from the bridge and created a VLAN with VLAN ID 7 and require service tag=yes then linked the vlan7 to ether1.
Then I created a pppoe connection to over vlan7. The mikrotik webgui says connected and I also get a Public IP from telco but I cannot ping the gateway or for example google dns 8.8.8.8
/ping interface=dsl src-address=217.226.18.x 8.8.8.8 says timeout. I also checked use default route for pppoe.
Can someone maybe look at the config below? I dont know what to do next.
# jan/03/1970 02:32:31 by RouterOS 6.44.3
# software id = VCG8-XXRM
# model = RBD52G-5HacD2HnD
# serial number = YXCYYXCYXCYX
add admin-mac=74:4D:28:55:62:77 auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX distance=indoors frequency=auto mode=ap-bridge ssid=MikroTik-55627B wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-XXXX distance=indoors frequency=auto mode=ap-bridge ssid=MikroTik-55627C wireless-protocol=802.11
/interface vlan
add interface=ether1 name=vlan7 use-service-tag=yes vlan-id=7
/interface pppoe-client
add add-default-route=yes allow=pap disabled=no interface=vlan7 name=dsl password=xxxx use-peer-dns=yes user=xxxx@t-online.de
/ip hotspot profile
add bridge=bridge comment=defconf interface=wlan2
set discover-interface-list=*2000011
add address=10.0.0.254/24 comment=defconf interface=bridge network=10.0.0.0
set allow-remote-requests=yes
/ip firewall address-list
add address=10.0.0.0/24 list=admin-access
add action=accept chain=input src-address-list=admin-access
add action=drop chain=input dst-port=21,22,23,80,443,8291 protocol=tcp
add action=masquerade chain=srcnat out-interface=dsl src-address=10.0.0.0/24
/ip ssh
set allow-none-crypto=yes forwarding-enabled=remote
/system logging
add disabled=yes topics=debug,pppoe
/tool sniffer
set file-limit=5000KiB file-name=pppoe-neu filter-cpu=1 filter-interface=all filter-stream=yes streaming-enabled=yes streaming-server=10.0.0.2
Okay Internet is working now the MTU und MRU was set to 1492 and service tag was set to no.
I had to wait a few minutes after I removed the use service tag option on pppoe interface dsl. It worked because something on telco side hang.
The working configuration is attached below. The Problem iam now facing is that my IPTV is very slow and hangs up every 10 seconds or so.
I checked the link speed and duplex and its set to 1gbit full duplex. I dont have any errors on the port where the TV is connected.
When the media box is started everytime a message appears: Playback not possible The quality of the network connection is bad. Please start the System Check (F104030)
When I change channel it works for a short period of time and then it hangs again after 10 seconds.
I have created a Wireshark Trace below. The Receiver Box has the ip 10.0.0.100
https://ufile.io/z7b4jx2g
# jan/02/1970 19:27:28 by RouterOS 6.44.3
# software id = YXYX-YXYX
# serial number = YXYXYXYX
set [ find default-name=ether2 ] full-duplex=no speed=100Mbps
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX disabled=no distance=indoors frequency=auto mode=ap-bridge ssid=icore2ghz wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-XXXX disabled=no distance=indoors frequency=auto mode=ap-bridge ssid=icore5ghz wireless-protocol=802.11
/interface vlan
add interface=ether1 name=vlan7 vlan-id=7
add add-default-route=yes disabled=no interface=vlan7 max-mru=1492 max-mtu=1492 name=dsl password=pwd user=admin
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=dynamic-keys supplicant-identity=MikroTik wpa-pre-shared-key=0123456789bcdefffeeddccbb wpa2-pre-shared-key=0123456789bcdefffeeddccbb
/ip hotspot profile
add name=lan ranges=10.0.0.0-10.0.0.100
add address-pool=lan disabled=no interface=bridge name=lan
add address=10.0.0.254/24 interface=bridge network=10.0.0.0
add address=10.0.0.0/24 comment=lan dns-server=8.8.8.8,8.8.4.4 gateway=10.0.0.254
add action=accept chain=input protocol=igmp
add action=accept chain=input protocol=udp
add action=accept chain=forward protocol=igmp
add action=accept chain=output protocol=igmp
/tool mac-server
/tool mac-server mac-winbox
/tool sniffer
set file-name=iptv filter-interface=bridge
