Mikrotik Blocking Output Traffic
again :slight_smile:
I’m using RB 450G at my work, with Winbox 5.13.
We have ViewCast Niagara 7550 for streaming. It works fine, tested on D-Link DiR-600 (It works without any router configurations), but when we connect it to Mikrotik it stops working.
Plus:
I can’t access Mikrotik router from home and can’t ping my public IP address from outside, it says “Request Timed Out”.
I don’t know if this two issues are connected with each other. Anyway, I need to fix both of them, so please help if you can.
Thats not a whole lot to go with.
Can you post your configuration?
