Mikrotik BNG: Issue IPv6 to clients using DHCP and Radius
Hello
Is it possible to provide IPV6 to clients with DHCP. It is quite easy with PPPOE but it seems more complicated if you don’t do PPPOE but DHCP.
Currently I am able to assign IPv4 to clients using DHCP and radius (no pppoe)
You can directly use DHCPv6 server, to hand PDs to clients with radius + dual stack queues to tie a RADIUS session for both IPv4 and IPv6 together for each server on a given VLAN.
It will work, but MikroTik doesn’t support ia_na, not mandatory, but it would be good if they did.
IPv4 config, similar to v6:
https://wiki.splynx.com/en/4_1/networking/authentication_of_customers/mikrotik_dhcp_radius
