hello eveyone i have a problem whit bridge mode on sxt 5 when i connect cat 6 cable from sxt to my vdsl modem lan port i couldnt connect to the mikrotik via winbox or http also i havent ping to the ip server configed for bridge mode ill show u my plan whit image also i tryed to set manual mikrotik router ip to ethernet adapter too nothing happned ( thank u for answer )
thank you so much for the answer but alrdy i tryed that one dosent work im so confused about that everything is true but when i put sxt cable (poe adapter connected to it ) into lan socket of modem vdsl couldnt get ping or connect to mikrotik thats weird if vdsl modem couldnt see the mikrotik radio howww i have a internet !!! even in the vdsl modem status client option cant detect radio to show me there is
only my pc client ! plus vdsl modem mode is on ethernet lan 1 i mean ppoe setup …
when i go back to rooter mode on mikrotik sxt i mean ppoe nd dhcp on sxt mikrotik ,my modem vdsl showing 2 client ! look at image pls im on rooter mode at this time
"Putting an IP address to a physical interface included in a bridge would mean actually putting it on the bridge interface itself. You can use /ip address print detail to see to which interface the address belongs to. "
“Two IP addresses from the same network assigned to routers different interfaces are not valid unless VRF is used. For example, the combination of IP address 10.0.0.1/24 on the ether1 interface and IP address 10.0.0.132/24 on the ether2 interface is invalid, because both addresses belong to the same network 10.0.0.0/24.”
on the Mikrotik and show us the result? suspect something else is causing the issue.
alternatively, reset the router and untick “default configuration”. this will wipe all the config out of the Mikrotik, then you only do two things: add two interface into the bridge, give the bridge an IP address, that’s all you need to use it as a bridge.
thank you for the answer i tryed to type ur code into terminal but wont work nd nothing happned to show u
sir i think this is not about mikrotik thats about second modem couldnt give me 2 gateway to see first mikrotik sxt someone told me
u can do it via telnet connect to ur modem but i didnt found any topic about this one to do this still wont see first sxt mikrotik every thing on mikrotik is true dhcps are true i have a internet
but cant connect to first sxt radio console !!!maybe all of problems are about dhcp and ppoe config on modem becuz i needed my modem options even routs are true idk what can i do !
mikrotik bridge address >>192.168.1.0/24
modem address>>192.168.0.3
also dhcp on modem 192.168.0.10/254
