Mikrotik bridge to get internet access from site B
Site A has internet connection, site B does not.
I have 2 old Mikrotik Sextant G I am configuring to get internet access at site B. A and B are about 1.5 km apart.
Site A has DHCP, the computers at site B has fixed IP not in the same subnet as site A.
I have set up a wireless bridge between the two routers and can see that they connect, but I cannot get any data through (from computers). Can not eaven access router A from computer in site B, or opposite. In WinFig or Winbox the signal strength, packets etc. are showing.
I am feeling that the problem is just to do a route or something, but I habe found no toturial or example that tlls me what or how to do this.
I hope there is someone here able to direct me in the right direction.
You will need an IP Address on each end of your wireless bridge, maybe an EoIP tunnel between them also
And then routes between them also.
You may get more attention posting this in the Beginner Basics or General forums.
There are also quite a few examples online if you search for Mikrotik Wireless Bridge Configuration
