Mikrotik can't connect to the Radius Manager.
Hi
I’ve just installed the latest version of the Radius Manager and it seems to be fine,the problem is that I don’t now how to setup that on the Mikrotik server.
I mean I want the Mikrotik and Radius manager to communicate to each other,can any one help me with this setup issue.
Thanks.
how do you authorize your users? pppoe, hotspot ?
I’m using pppoe,can you help?
thanks
show us your configuration of pppoe, where you have entered the RADIUS address
I think the following might help.
[admin@Test Board] /radius> print
Flags: X - disabled
SERVICE CALLED-ID DOMAIN ADDRESS SECRET
0 ppp 66.8.66.6 tes...
login
hotspot
wireless
[admin@Test Board] /ppp profile> print
Flags: * - default
0 * name="default" use-compression=default use-vj-compression=default
use-encryption=default only-one=default change-tcp-mss=yes
1 * name="default-encryption" local-address=192.168.0.112
remote-address=66.8.66.6 use-compression=default
use-vj-compression=default use-encryption=yes only-one=default
change-tcp-mss=yes dns-server=66.8.66.2
