Mikrotik CAP ac - How to change cases / metal ring
Hey,
i just got the new Mikrotik CAP ac, but i fail to switch cases and to unmount the metal ring on it’s back.
Since i don’t want to use raw power, I am asking you guys:
What’s the trick about disamble the device?
Picture:
Turning the metal ring simply counter-clockwise doesn’t work for me.
At the left opening in the metal ring you see a plastic tab. You have to apply more force when turning to the metal ring to the left. You can also push the plastic tab to the outside.
ah!
i really needed a lot of power, so much that i was afraid to breaking it.
however it’s working fine now and i can enjoy mikrotik device no. 5 in my home :slight_smile:
thanks!
