Having recently received my cAP AX, I started to configure it to serve as an access point with a separate subnet.
Setup should be like follows:
rb-Bridge: <-> rb4011 Ether10 <-> cAP AX Bridge
ether1-9 Ether1-2
wifi1-2
Goal is to have subnets:
All devices on the rb4011 bridge
192.168.1.0/24
All devices on the AP (DHCP server serving at ether10 on routerboard)
192.168.2.0/24
DHCP Servers are in the RB. rb-bridge has DHCP server serving address pools for 192.168.1.2-254 network and Ether10 has DHCP server for serving pools 192.168.2.2-254
Default configuration in the cAP AX has
Bridge
- ether2
- wifi1-2
- DHCP server 192.168.88.1/24
Ether1
- DHCP client
Initially the device works fine with the factory configs, but as I try to either move the ether1 interface to the bridge, disable DHCP client and use static IP address, remove DHCP server, I get disconnected and cannot connect back unless I do a factory reset. So I figure I have something wrong in my steps to achieve the desired subnets or missing some part of the configurations needed ![]()
What could be good pointers to correct procedures to:
- Implementing so that all interfaces on cAP AX are part of the bridge on the AP and successfully become part of the subnet 192.168.2.0/24
- Use the RB4011’s DHCP server on interface ether10 for all devices using the AP. (I attempted to implement a DHCP relay as well by reading through the documentation, but DHCP requests were not relayed properly so probably I did a misconfiguration there)
# factory config
# only changed so that ether1 is on LAN interface list to allow mgmt host to connect from desktop
add admin-mac=48:A9:8A:A2:90:01 auto-mac=no comment=defconf name=bridge
/interface wifiwave2
set [ find default-name=wifi1 ] channel.band=5ghz-ax .skip-dfs-channels=\
10min-cac .width=20/40/80mhz configuration.mode=ap .ssid=MikroTik-A29002 \
disabled=no security.authentication-types=wpa2-psk,wpa3-psk
set [ find default-name=wifi2 ] channel.band=2ghz-ax .skip-dfs-channels=\
10min-cac .width=20/40mhz configuration.mode=ap .ssid=MikroTik-A29003 \
add comment=defconf name=WAN
add comment=defconf name=LAN
add address-pool=default-dhcp interface=bridge lease-time=10m name=defconf
add bridge=bridge comment=defconf interface=wifi1
add bridge=bridge comment=defconf interface=wifi2
add interface=ether1 list=LAN
192.168.88.0
/ip dhcp-client
192.168.88.1
set allow-remote-requests=yes
/ip dns static
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
add action=drop chain=forward comment="defconf: drop invalid" connection-state=\
invalid
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" \
connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=\
out,none out-interface-list=WAN
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
"defconf: drop everything else not coming from LAN" in-interface-list=!LAN
invalid
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" \
src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" \
dst-address-list=bad_ipv6
icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 \
protocol=udp
ipsec-ah
ipsec-esp
/system clock
set time-zone-name=Europe/Helsinki
/system note
set show-at-login=no
/system routerboard mode-button
set enabled=yes on-event=dark-mode
/system script
add comment=defconf dont-require-permissions=no name=dark-mode owner=*sys \
policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
source="\r\
\n :if ([system leds settings get all-leds-off] = \"never\") do={\r\
\n /system leds settings set all-leds-off=immediate \r\
\n } else={\r\
\n /system leds settings set all-leds-off=never \r\
\n }\r\
\n "
/tool mac-server
/tool mac-server mac-winbox
