Mikrotik CCR 1009 cant access servers (Same IP as subnet)
I am small ISP using Mikrotik CCR 1009. I have few issues as i am NOOB when it comes to ROS. I will list them in two or three separate threads.
Config are as follows.
  1. Sfp 1 is WAN 1 (telco 1)
  2. Eth 1 is WAN 2 (telco 2) 2nd line for redundancy
  3. ETH 2 is main Output to clients running PPPoE server with Pool 103.xxx.x79.1 /24
    PPPoE Pool1 is 103.xxx.x79.60 to 254 (2-60) is reserved for static clients or later use
  4. DMA is my radius server. Its IP is 103.xxx.x79.49
Now this is very strange issue. I think its something to do with subnetting.
Now i cannot access my Radius Server ( 103.xxx.x79.49 ) from my Clients side (PPPoE Clients) that are using above POOL (obviously)
But I can access my radius server from everywhere (other ISP), 4g mobile except from my own clients end.
Hope somebody can help me on this.
bump
https://forum.mikrotik.com/viewtopic.php?t=182601
You are missing some information required to assist.
On SECOND THOUGHT, STICK TO ONE THREAD PLEASE.
GO HERE to post the additional information!!
http://forum.mikrotik.com/t/mikrotik-ccr-1009-two-ip-pools-24-ppoe-server/155522/1
thank you so much for the suggestion
  1. missing info as in. … i have made representation of IP as the tips mentioned in your thread. as these are Public IPS.
  2. Both are different issues.so kept a separate thread as to not mix both issues for confusions
IF its the same network, only want one series of posts…
Follow the SIMPLE guide I provided.
Diagram, detailed requirements
and then list issues. No one likes bouncing between posts for the same network.
If its a different network my apologies.
