I have a mikrotik ccr 1036-8g-2s+ with about 10 filter rule and per your datasheet on https://mikrotik.com/product/CCR1036-8G-2Splus in routing mode with 25 filter rule 1036 can handle 1.5gbps bps and 3m pps but the issue here is when i receive DDOS attack my CPU usage is %100,
the DDoS i received had 1m PPS and about 1gbps bps and i have analyzed the traffic, they were with spoofed IPs, they were on UDP and sometimes GRE protocol, they were on one DST IP.
as a note my uplinks are 2x 10gbps so I have 20gbps totally.
This is what i have on my router:
6 enabled Ip Firewall Filter rules
1 Mangle Rules
9 enable ip firewall raw rules
bgp with no full table
100 Vlans
BGP/OSPF
would you tell me, why does my cpu usages is %100 when i receive this amount ? its opposite of datasheet.
any idea to solution for solve this?
i sent an email to support@mikrotik.com but they suggested me some rules for fighting ddos, how ever i do not want protect my customers from ddos attacks and i want to transit this traffic to them because we do not offer ddos protection service! so i do not know why does datasheet numbers are really different in working enviroments!
Do you have connection tracking enabled?
was the ddos on ipv6? there was an issue with that not so long ago (implementation in ROS), with a patch release. do you have it?
which version are you running? remember that there was a bug in ROS with regards to that;
Ros 6.45.1:
*) firewall - process packets by firewall when accepted by RAW with disabled connection tracking;
