i have 2x Nexus 3064 and i have 1x CCR 1072 and 1x CCR 1036 8g 2S+ so i want to connect one of the nexuses to ccr 1072 and another nexus to 1036 (i want to connect nexus console port to mikrotik console port) and use mikrotik devices as out of band services for my nexus, so i should use cross cable and connect one side to nexus console port and other side to mikrotik console port ? and set baud rate to 9600 then connect to serial port in mikrotik and use my cisco ?
Thank you.
Never used it between mikrotik and cisco, only between two mikrotiks, so can’t say about the needed baud rate.
But don’t forget to disable serial console on mikrotik’s serial port.
And also set silent-boot=yes in /system routerboard settings.
when i set slient-boot do i need rebootthe router?
I have used to connect from MT router to connect to Cisco serial port. Works fine.
i just need to create a rollover cable and connect both console port, right? what baud-rate did oyu set?
I’m not sure: this setting is needed to prevent mikrotik from writing into console port on startup.
But I don’t know if it will be applied on first reboot or after it.
i just did and it works,
i used an rollover cable
