Mikrotik CCR memory leakage
Hi everybody,
I have a Mikrotik CCR ( v. 6.12) running as a hotspot gateway, however, i’m encountring many stability issues. the MK behaves strangly, sometimes it works fine sometime it’s not. it seems like a memory leakage issue.
Does anybody heard about the memory leakage issue on CCR product line??
Thx
Upgrade to 6.19 and see if that fixes it.
Thx for the answer, is the 6.19 available on the support?? or is it anywhere else?
Yes it is available from www.mikrotik.com/download
