I’m having a strange SFP port issue with my CCR-1036-12G-4S router.
As soon as I reboot the router, the SFP port goes down. I manually have to disable and enable the SFP port to work again. The Auto-negotiation is disabled and the speed is set to 1G.
The line came from a media converter which auto negotiates to 1G when connected to switch via ethernet cable.
Also, the same link works perfectly with SFP module, when connected to RB3011, 4011.
This is why I’m confused. Is there any settings to be done from the CCR end to have it running without scripts??
