Follows the router export. just remembering the processor is no more than 2% percent.
add mtu=1500 name=Loopback protocol-mode=none
set [ find default-name=ether1 ] l2mtu=1590 name=ether1_WAN
set [ find default-name=ether2 ] l2mtu=1590 name=ether2_SAO_JOSE
set [ find default-name=ether3 ] l2mtu=1590 name=ether3_TAMANDARE
set [ find default-name=ether4 ] l2mtu=1590
set [ find default-name=ether5 ] l2mtu=1590 name=ether5_iDrac
set [ find default-name=ether6 ] l2mtu=1590 name=ether6_CACHE speed=1Gbps
set [ find default-name=ether7 ] l2mtu=1590 name=ether7_MARAGOGI
set [ find default-name=ether8 ] l2mtu=1590
set [ find default-name=ether9 ] l2mtu=1590
set [ find default-name=ether10 ] l2mtu=1590
set [ find default-name=ether11 ] l2mtu=1590
set [ find default-name=ether12 ] l2mtu=1590
set [ find default-name=sfp1 ] l2mtu=1590 name=sfp1_FIBRA_MORAES
set [ find default-name=sfp2 ] auto-negotiation=no l2mtu=1590
set [ find default-name=sfp3 ] auto-negotiation=no l2mtu=1590
set [ find default-name=sfp4 ] auto-negotiation=no l2mtu=1590
/interface vlan
add interface=ether1_WAN l2mtu=1586 name=VLAN0402 vlan-id=402
add disabled=yes interface=ether1_WAN name=vlan830-TESTE-TTVI vlan-id=830
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=3des
/queue type
set 0 pfifo-limit=200
set 9 pfifo-limit=200
/queue tree
add disabled=yes max-limit=200M name=facebook_in packet-mark=facebook_in parent=global
priority=1 queue=default
add disabled=yes max-limit=800M name=http packet-mark=http parent=global priority=1
queue=default
add disabled=yes max-limit=330M name=Outros packet-mark=other parent=global priority=4
queue=default
add disabled=yes max-limit=30M name=p2p packet-mark=p2p parent=global queue=default
add disabled=yes max-limit=200M name=Youtube packet-mark=youtube_in parent=global
priority=3 queue=default
/routing bgp instance
set default disabled=yes
add as=263103 client-to-client-reflection=no name=BGP_1 redistribute-connected=yes
router-id=186.225.46.142
/routing ospf instance
set [ find default=yes ] distribute-default=always-as-type-1 name=OSPF_VIVANET
redistribute-connected=as-type-1 redistribute-static=as-type-1 router-id=
10.255.0.1
/snmp community
set [ find default=yes ] name=vivanet
/system logging action
set 0 memory-lines=100
set 1 disk-lines-per-file=100
/ip settings
set allow-fast-path=no
add address=186.225.46.142/30 comment=“WIRELINK (LINK) IP DE TESTE 186.225.47.94”
interface=VLAN0402 network=186.225.46.140
add address=10.1.109.254/24 comment=“PTPT - SAO_JOSE/MORAES” interface=
sfp1_FIBRA_MORAES network=10.1.109.0
add address=10.1.112.254/24 comment=“PTPT - SAO JOSE / TAMANDARE” interface=
ether3_TAMANDARE network=10.1.112.0
add address=10.255.0.1 comment=OSPF-LOOPBACK interface=Loopback network=10.255.0.1
add address=186.235.240.65/30 comment=“REDE BARREIROS” interface=sfp1_FIBRA_MORAES
network=186.235.240.64
add address=186.235.240.69/30 comment=“REDE S\C3O JOS\C9” interface=ether2_SAO_JOSE
network=186.235.240.68
add address=10.1.111.254/24 comment=“AP - VIVANET AL” interface=ether7_MARAGOGI
network=10.1.111.0
add address=186.235.240.81/29 comment=“SERVIDOR CACHE (NAO HABILITAR )” disabled=yes
interface=ether5_iDrac network=186.235.240.80
add address=10.10.2.1/30 comment=“CACHE PEERAPP” disabled=yes interface=ether6_CACHE
network=10.10.2.0
add address=186.235.240.89/30 comment=“REDE VARZEA” interface=ether3_TAMANDARE
network=186.235.240.88
add address=186.235.240.93/30 comment=“REDE TAMANDARE” interface=ether3_TAMANDARE
network=186.235.240.92
add address=186.235.240.97/30 comment=“REDE ABREU” interface=ether3_TAMANDARE network=
186.235.240.96
add address=186.235.240.81/30 comment=“REDE TORRE PONTA DE MANGUE” interface=
ether7_MARAGOGI network=186.235.240.80
add address=186.235.240.85/30 comment=“REDE TORRE CAJU” interface=ether7_MARAGOGI
network=186.235.240.84
add address=177.38.204.235/29 disabled=yes interface=vlan830-TESTE-TTVI network=
177.38.204.232
set cache-size=8192KiB servers=
186.235.240.58,186.235.240.60,186.225.46.181,186.225.46.177
add action=drop chain=input comment=“BLOQUEIO DE PORTA 8080” dst-address=
186.235.240.0/21 dst-port=8080 log-prefix=“BLOK PORT 8080” protocol=tcp
/ip firewall service-port
set ftp disabled=yes
set tftp disabled=yes
set sip disabled=yes
/ip hotspot ip-binding
add address=10.1.111.1 comment=“RADIO VIVANET AL”
add address=10.1.111.2 comment=“RADIO TORRE CAJU”
add address=10.1.111.3 comment=“RADIO TORRE PONTA DE MANGUE”
add address=10.1.111.4 comment=“RADIO BEACH HOUSE”
add address=10.1.111.5 comment=“RADIO LIVRE” disabled=yes
/ip ipsec policy
set 0 dst-address=0.0.0.0/0 src-address=0.0.0.0/0
/ip proxy
set cache-path=web-proxy1 max-cache-size=none src-address=0.0.0.0
add check-gateway=ping comment=“ROTA PEERAPP” disabled=yes distance=1 gateway=
186.225.46.141 routing-mark=route_DOWNSTREAM_PEERAPP
10.10.2.2 routing-mark=route_UPSTREAM_PEERAPP
add distance=1 gateway=186.225.46.141
add disabled=yes distance=1 gateway=186.225.46.141
add comment=“Load balance 1” distance=1 dst-address=186.225.46.1/32 gateway=
186.225.46.141
/ip service
set telnet disabled=yes
set ssh address=186.235.240.0/21
set api disabled=yes
/lcd
set default-screen=informative-slideshow read-only-mode=yes
/radius incoming
set accept=yes
/routing bgp network
add network=186.235.240.0/21 synchronize=no
add network=186.235.240.0/24 synchronize=no
add network=186.235.241.0/24 synchronize=no
add network=186.235.242.0/24 synchronize=no
add network=186.235.243.0/24 synchronize=no
add network=186.235.244.0/24 synchronize=no
add network=186.235.245.0/24 synchronize=no
add network=186.235.246.0/24 synchronize=no
add network=186.235.247.0/24 synchronize=no
add network=186.235.240.0/22 synchronize=no
add network=186.235.240.0/23 synchronize=no
add network=186.235.244.0/22 synchronize=no
add network=186.235.242.0/23 synchronize=no
add network=186.235.244.0/23 synchronize=no
add network=186.235.246.0/23 synchronize=no
/routing bgp peer
add cisco-vpls-nlri-len-fmt=auto-bytes in-filter=as_28368_in instance=BGP_1 multihop=
yes name=Wirelink out-filter=as_28368_out remote-address=186.225.46.141 remote-as=
28368 ttl=default update-source=VLAN0402
/routing filter
add action=accept chain=as_28368_out prefix=186.235.240.0/21 prefix-length=21-24
add action=discard chain=as_28368_out
add action=accept chain=as_28368_in set-bgp-local-pref=200
add action=discard chain=as_28368_in
/routing ospf network
add area=backbone comment=BORDA/SAO_JOSE network=186.235.240.68/30
add area=backbone comment=“REDE LOOPBACK” network=10.255.0.0/24
add area=backbone comment=“BORDA/TAMANDAR\C9” network=186.235.240.92/30
add area=backbone comment=BORDA/BARREIROS network=186.235.240.64/30
add area=backbone comment=BORDA/VARZEA network=186.235.240.88/30
add area=backbone comment=BORDA/ABREU network=186.235.240.96/30
add area=backbone comment=BORDA/CAJU network=186.235.240.84/30
add area=backbone comment=“BORDA / PONTA DE MANGUE” network=186.235.240.80/30
/snmp
set contact=vivanet.net.br enabled=yes location=“S\E3o Jos\E9 da Coroa Grande”
trap-version=2
/system clock
set time-zone-autodetect=no time-zone-name=America/Recife
/system identity
set name="ROTEADOR BORDA CENTRAL SAO JOSE "
/system leds
set 1 interface=sfp1_FIBRA_MORAES
set 2 interface=sfp1_FIBRA_MORAES
set 3 interface=sfp1_FIBRA_MORAES
/system ntp client
set enabled=yes primary-ntp=201.49.148.135 secondary-ntp=200.192.232.8
/system routerboard settings
set cpu-frequency=1200MHz memory-frequency=1066DDR
