Thanks for the input, I am perplexed though because I got the following information from Mikrotik:
1ST RESPONSE
This is normal behavior. PSU with the highest voltage will be the one which is used.
2ND RESPONSE
In this case, you have the same voltage for both PSUs, which is why the load is split.
Regarding the failure, if you see that the voltage has dropped on one of the PSUs, that would mean that the PSU is failed.
If you can do a “lab test”, then remove PSU2 and see if device keeps running afterwards … without any hiccups. With failing PSU you’d see strange things happen quite soon.
