Mikrotik Chateau 5G L2TP help please
I have a Chateau 5G on Vodafone, which I have managed to get configured and is working great, I now want to use the Andrew and Arnold L2TP tunnel service to get around CGNat.
I've followed their support page article which is meant for the RB3011/ 4011 devices, the tunnel comes up but no traffic goes across it.
Would anyone be able to take a look please and see what is missing or incorrect.
My local lan is 10.0.1.254/24 and this is the config.
2025-12-31 02:47:20 by RouterOS 7.12.1
software id = XXXX-XXXX
model = D53G-5HacD2HnD
serial number = XXXXXXXXXXX
add name=Lan-Bridge
/interface lte
set [ find default-name=lte1 ] allow-roaming=no band="" nr-band=""
/interface wireless
set [ find default-name=wlan1 ] ssid=MikroTik
set [ find default-name=wlan2 ] ssid=MikroTik
add name=WAN
add name=LAN
/interface lte apn
/ip hotspot profile
/interface l2tp-client
add comment="Andrew and Arnold L2TP" connect-to=l2tp.aa.net.uk disabled=no max-mru=1340 max-mtu=1340 name=l2tp-AAISP
profile=default use-peer-dns=exclusively user=XXXXXXXXXx
/zerotier
set zt1 comment="ZeroTier Central controller - https://my.zerotier.com/" disabled=yes disabled=yes name=zt1 port=9993
add bridge=Lan-Bridge interface=ether1
add bridge=Lan-Bridge interface=ether2
add bridge=Lan-Bridge interface=ether3
add bridge=Lan-Bridge interface=ether4
add bridge=Lan-Bridge interface=ether5
add bridge=Lan-Bridge interface=wlan2
add bridge=Lan-Bridge interface=wlan1
add interface=lte1 list=WAN
add interface=Lan-Bridge list=LAN
add address=10.0.1.254/24 interface=Lan-Bridge network=10.0.1.0
/ip dhcp-client
add disabled=yes interface=*8
add action=accept chain=input comment="Input: allow established and related" connection-state=established,related
add action=accept chain=forward comment="Forward: allow established and related" connection-state=established,related
add action=accept chain=input comment="Input: allow all ICMP" protocol=icmp
add action=accept chain=input comment="Input: allow all from Lan-Bridge" in-interface=Lan-Bridge
add action=accept chain=forward comment="Forward: allow all from Lan-Bridge" in-interface=Lan-Bridge
add action=drop chain=input comment="Input: drop all remaining traffic"
add action=drop chain=forward comment="Forward: drop all remaining traffic"
/ip firewall mangle
add action=change-mss chain=forward comment="TCP: Clamp MSS to PMTU" new-mss=clamp-to-pmtu out-interface=l2tp-AAISP
passthrough=yes protocol=tcp tcp-flags=syn
add action=masquerade chain=srcnat comment="Nat: masquerade 10.0.1.0/24 to l2tp-AAISP's address" src-address=10.0.1.0/24
/system clock
set time-zone-name=Europe/London
/system note
set show-at-login=no
/system routerboard settings
set auto-upgrade=yes
Cheers
Tony
Post a link to the doc/example you followed.
At first sight the NAT rule:
looks incomplete, it misses an out-interface or out-interface-list specification.
@jaclaz i'll have a look at the NAT statement after tea, the link I followed was https://support.aa.net.uk/L2TP_Client:_Routerboard
  1. Go to the NAT tab, and add a new rule with +:
  1. General, Chain: "srcnat"
  2. General, Src. Address: "192.168.88.0/24"
  3. General, Out. Interface: "l2tp-aaisp"
  4. Action, Action: "masquerade"
  5. Comment: "NAT: masquerade 192.168.88.0/24 to l2tp-aaisp's address"
  6. Save the rule with OK. This rule will show up in red with a warning until we enable the l2tp-aaisp interface in a moment.
@jaclaz , thank you for the reply, I have added the missing NAT rule, unfortunately it doesn't seem to have helped.
This is the current config after the NAT change.
2026-01-06 02:53:49 by RouterOS 7.20.6
software id = xxxx-xxxx
serial number = xxxxxxxxxxx
add name=Lan-Bridge
/interface wireless
/interface lte
add name=WAN
add name=LAN
/interface lte apn
add comment="Andrew and Arnold L2TP" connect-to=l2tp.aa.net.uk disabled=no max-mru=1340 max-mtu=1340 name=l2tp-AAISP profile=default use-peer-dns=exclusively
user=xxxxxxxx
/ip dhcp-client
add disabled=yes interface=ether4
/ip firewall mangle
add action=change-mss chain=forward comment="TCP: Clamp MSS to PMTU" new-mss=clamp-to-pmtu out-interface=l2tp-AAISP protocol=tcp tcp-flags=syn
add action=masquerade chain=srcnat comment="Nat: masquerade 10.0.1.0/24 to l2tp-AAISP's address" out-interface=l2tp-AAISP src-address=10.0.1.0/24
/system clock
/system note
Any other suggestions or tests I could do to try and see where the issue lies?
@StaffsTony
Hi, please mark code with prefermatted code tag using < / > button
Post the output of:
/ip route print
Check what happens with a traceroute.
