What is wrong here? I can ping upgrade.mikrotik.com IP address, also i don’t have any firewall blocking anything. I have same identical device in VRRP (HA) pair which has no issue.
One more reason for this problem - ROS upgrade fail with these symptoms:
finding out latest version…
ERROR: connection timed out
Special ‘option’ package installed. I don’t know how normal user can do that, but it was done to my device by MikroTik support team. They installed it and left it forever. And no one informed me that it’s potentially dangerous and can affect to the normal device functionality. BTW, it remains even when ROS have been updated manually or/and device restarted. So, I lived with this package for 1 year!!!
Here is how this package looks like:
How to solve the issue?
Press Uninstall, it will change appearance to grayed-out and change status to Scheduled. Then, reboot the device.
And you are done! Now you can upgrade ROS by pressing Check for Updates.
