Mikrotik CHR AWS Disaster Recovery Plan
Hi Team,
Just wondering what peoples DR plans are for Mikrotik CHR in AWS if they lose connection to their instance?
Example I tried to migrate from one chr to another by backup and restore, after reboot I couldn’t connect anymore and there is no console option like with a Windows or Linux device to get access to the interface.
Or example if I make an epic mistake and can no longer get connected.
I was think about setting up a windows box on the same LAN in AWS? Is there a better way?
I know there is a safe mode option but I’d like a backup plan to the back if you know what I mean.
Any ideas? Ta
Hopefully you figured out that restoring a backup, also restores all IP and mac-addresses … so in AWS that is almost certainly a good way to lock yourself out…
I’d say using the EC2 key-pair used to install AWS CHR, isn’t a bad plan… It’s restoring a backup from a DIFFERENT instance on a NEW one that’s the DR inducing situation IMO.
Bring up a windows instance, with winbox is option too. I do exactly this with VMWare for CHR, with a windows instance on the VMWare, so Layer2 access to CHR should be possible. At AWS, while cost something to bring up a Windows EC2, you’d only need to bring it up if DR/failure… (or perhaps a few pennies a month to save the disk once winbox/etc was setup)
