I am using a Metal 52 ac on a machine that is moved between sites. At each site there is 2.5G WiFi available, but each site has a different SSID. Some require are open and some require password. Currently a user must connect to the Mikrotik and manually connect to each network.
Is it possible to setup the Mikrotik so it has several SSIDs that it could connect to if they were available. (Like station roaming, but with different networks.)
