Hi
I have a Mikrotik Cloud Router Switch 125-24G-1S-IN that I want to use for a Wireless zone. I have 2 FTTH lines with a speed of 300/300Mbps each one. When I run a speed test with the computer connected to an ethernet port of the fiber modems (ONTs), I get the 300/300 full speed. However when I connect the computer to the mikrotik, I get 150/200Mbps in the speed test.
First I have deactivated all the mangle rules in the firewall but the test gives me the same result. I have followed the instructions in the wiki to have the load balancing between the 2 lines with PCC.
I have done the test with all rules deactivated except the NAT. This router switch has 1Gb ports so I don´t understand why I don´t get the maximum bandwidth.
I must say that the mikrotik has 3 VLANs configured. Maybe this is overloading it?
Any help will be appreciated, thanks.
