mikrotik.com ipv6 problem?
I can only get to forum.mikrotik.com/www.mikrotik.com with ipv4.. ipv6 (At least via he.net) isnt working…
Only me?
telnet -6 forum.mikrotik.com
GET / HTTP/1.0
works fine for me. AAAA record resolves.
That’s behind a HE tunnel as well.
I have similar problem with routerboard.com
core1.lon1.he.net> traceroute ipv6 2a02:610:7501:1000::2
Sending DNS Query to 65.19.175.2
Sending DNS Query to 65.19.176.2
Sending DNS Query to 209.51.180.102
Tracing the route to IPv6 node 2a02:610:7501:1000::2 from 1 to 30 hops
1 19 ms 17 ms 14 ms 10gigabitethernet1-1.core1.ams1.he.net [2001:470:0:3f::2]
2 15 ms 19 ms 18 ms 10gigabitethernet1-1.core1.fra1.he.net [2001:470:0:47::2]
3 * * * ?
4 * * * ?
5 * * * ?
6 * * * ?
IP: Errno(8) Trace Route Failed, no response from target node.
Entry cached for another 13 seconds.
core1.dal1.he.net> traceroute ipv6 2a02:610:7501:1000::2
Tracing the route to IPv6 node from 1 to 30 hops
1 22 ms 25 ms 24 ms 10gigabitethernet5-4.core1.atl1.he.net [2001:470:0:1b6::2]
2 33 ms 39 ms 32 ms 10gigabitethernet6-4.core1.ash1.he.net [2001:470:0:1b5::1]
3 46 ms 49 ms 39 ms 10gigabitethernet1-2.core1.nyc4.he.net [2001:470:0:36::2]
4 112 ms 107 ms 117 ms 10gigabitethernet1-2.core1.lon1.he.net [2001:470:0:3e::2]
5 115 ms 130 ms 118 ms 10gigabitethernet1-1.core1.ams1.he.net [2001:470:0:3f::2]
6 124 ms 124 ms 126 ms 10gigabitethernet1-1.core1.fra1.he.net [2001:470:0:47::2]
7 * * * ?
8 * * * ?
9 * * * ?
10 * * * ?
Entry cached for another 29 seconds.
core1.hkg1.he.net> traceroute ipv6 2a02:610:7501:1000::2
1 167 ms 155 ms 155 ms 2001:470:0:16b::1
2 217 ms 224 ms 226 ms 2001:470:0:10e::2
3 284 ms 287 ms 285 ms 2001:470:0:3e::2
4 302 ms 301 ms 300 ms 2001:470:0:3f::2
5 305 ms 301 ms 301 ms 2001:470:0:47::2
6 * * * ?
7 * * * ?
8 * * * ?
9 * * * ?
Entry cached for another 25 seconds.
tracing from several of HE routers, the web site is unavailable over ipv6…
while at the same time over my other ipv6 BGP session from Cogent:
TRACE from Frankfurt to routerboard.com
1 2001:978:1:31a::1 0.733 ms 0.571 ms
2 * *
3 * *
4 * *
5 2001:1900:4:3::c1 99.017 ms 98.238 ms
6 2001:1900:15:7::3 100.016 ms 2001:1900:15:6::3 98.945 ms
7 2001:1900:6:1::15 189.232 ms 188.421 ms
8 2001:1900:5:2:2::19e 203.984 ms 203.010 ms
9 RT.TNR.HKI.FI.retn.net (2a02:2d8::57f5:e096) 226.078 ms 225.320 ms
10 2a02:610:ffff:1000::1 235.545 ms 233.019 ms
11 2a02:610:ffff:1003::2 233.612 ms 232.969 ms
12 2a02:610:7500::1 233.299 ms 231.066 ms
13 2a02:610:7500:8::2 233.593 ms 231.367 ms
14 2a02:610:7500:9::2 234.031 ms 233.366 ms
15 2a02:610:7501:1000::1 295.983 ms 274.265 ms
16 2a02:610:7501:1000::2 296.917 ms 269.813 ms
I think that ipv6 internet is very broken at the moment… :frowning:
If you get your IPv6 via BGP from someone then be aware that under ROS 4 it’s buggy and unstable, try restarting the BGP peer and see if that helps
no… my BGPv6 sessions are on Cisco ASR 1006, via tunnel to Hurricane Electric, and native to Cogent…
so no problem there… and I don’t have problems accessing the rest of IPv6 internet, just the route 2a02:610::/32, AS2588 Latnet ISP.
can someone confirm/replicate the issue?
yesterday was the problem only with routerboard.com, but today also with mikrotik.com and its subdomains.
let’s continue discussion here: http://forum.mikrotik.com/t/mikrotik-ipv6-addresses/44849/1
