mikrotik.com is broken, certificate chain is incomplete
Looks like mikrotik.com is broken for some clients. According to SSL Labs and Internet.nl the certificate chain is incomplete.
Example using curl on Debian 11:
$ curl --version
curl 7.74.0 (x86_64-pc-linux-gnu) libcurl/7.74.0 OpenSSL/1.1.1n zlib/1.2.11 brotli/1.0.9 libidn2/2.3.0 libpsl/0.21.0 (+libidn2/2.3.0) libssh2/1.9.0 nghttp2/1.43.0 librtmp/2.3
Release-Date: 2020-12-09
Protocols: dict file ftp ftps gopher http https imap imaps ldap ldaps mqtt pop3 pop3s rtmp rtsp scp sftp smb smbs smtp smtps telnet tftp
Features: alt-svc AsynchDNS brotli GSS-API HTTP2 HTTPS-proxy IDN IPv6 Kerberos Largefile libz NTLM NTLM_WB PSL SPNEGO SSL TLS-SRP UnixSockets
$ curl -Ivv https://mikrotik.com
*   Trying 2a02:610:7501:2000::205:443...
* Connected to mikrotik.com (2a02:610:7501:2000::205) port 443 (#0)
* ALPN, offering h2
* ALPN, offering http/1.1
* successfully set certificate verify locations:
*  CAfile: /etc/ssl/certs/ca-certificates.crt
*  CApath: /etc/ssl/certs
* TLSv1.3 (OUT), TLS handshake, Client hello (1):
* TLSv1.3 (IN), TLS handshake, Server hello (2):
* TLSv1.3 (IN), TLS handshake, Encrypted Extensions (8):
* TLSv1.3 (IN), TLS handshake, Certificate (11):
* TLSv1.3 (OUT), TLS alert, unknown CA (560):
* SSL certificate problem: unable to get local issuer certificate
* Closing connection 0
curl: (60) SSL certificate problem: unable to get local issuer certificate
More details here: https://curl.se/docs/sslcerts.html
curl failed to verify the legitimacy of the server and therefore could not
establish a secure connection to it. To learn more about this situation and
how to fix it, please visit the web page mentioned above.
$ curl -Ivv --insecure https://mikrotik.com
* ALPN, offering h2
* TLSv1.3 (IN), TLS handshake, CERT verify (15):
* TLSv1.3 (IN), TLS handshake, Finished (20):
* TLSv1.3 (OUT), TLS change cipher, Change cipher spec (1):
* TLSv1.3 (OUT), TLS handshake, Finished (20):
* SSL connection using TLSv1.3 / TLS_AES_256_GCM_SHA384
* ALPN, server did not agree to a protocol
* Server certificate:
*  subject: businessCategory=Private Organization; jurisdictionC=LV; serialNumber=40003286799; C=LV; L=Riga; O=Mikrotikls SIA; CN=mikrotik.com
*  start date: Jan 26 00:00:00 2022 GMT
*  expire date: Feb 26 23:59:59 2023 GMT
*  issuer: C=US; O=DigiCert Inc; OU=www.digicert.com; CN=DigiCert SHA2 Extended Validation Server CA
*  SSL certificate verify result: unable to get local issuer certificate (20), continuing anyway.
> HEAD / HTTP/1.1
> Host: mikrotik.com
> User-Agent: curl/7.74.0
> Accept: */*
* TLSv1.3 (IN), TLS handshake, Newsession Ticket (4):
* old SSL session ID is stale, removing
* Mark bundle as not supporting multiuse
< HTTP/1.1 200 OK
HTTP/1.1 200 OK
< Date: Mon, 23 Jan 2023 17:36:51 GMT
< Server: Apache
Server: Apache
< Vary: Referer,Host
Vary: Referer,Host
< X-Content-Type-Options: nosniff
< X-XSS-Protection: 1; mode=block
< X-Frame-Options: sameorigin
< X-Permitted-Cross-Domain-Policies: master-only
< Strict-Transport-Security: max-age=63072000; includeSubDomains
< Cache-Control: no-cache, no-store, must-revalidate
< Pragma: no-cache
Pragma: no-cache
< Expires: -1
Expires: -1
< Access-Control-Allow-Origin: http(s)?://(www\.)?mikrotik.com$
< Content-Security-Policy: default-src 'self';object-src 'self' *.cdn.datatables.net cdn.datatables.net;connect-src 'self' *.mt.lv maps.googleapis.com fonts.googleapis.com *.doubleclick.net;script-src 'self' 'unsafe-inline' 'unsafe-eval' data: unpkg.com i.mt.lv *.google.com gstatic.com code.jquery.com *.gstatic.com www.google-analytics.com googleapis.com *.googleapis.com *.mikrotik.com mikrotik.com;style-src 'self' 'unsafe-inline' i.mt.lv fonts.googleapis.com unpkg.com *.mikrotik.com mikrotik.com code.jquery.com use.typekit.net www.mikrotik.com;img-src 'self' data: i.mt.lv i.ytimg.com api.tiles.mapbox.com *.tile.openstreetmap.org unpkg.com *.arcgisonline.com stats.g.doubleclick.net www.google-analytics.com mikrotik.com www.mikrotik.com forum.mikrotik.com 1.aerial.maps.cit.api.here.com 2.aerial.maps.cit.api.here.com 3.aerial.maps.cit.api.here.com 4.aerial.maps.cit.api.here.com gstatic.com http://services.ga.gov.au *.gstatic.com *.googleapis.com *.arcgisonline.com *.google.com *.google.lv *.routerboard.com;frame-src 'self' youtu.be youtube.com www.youtube.com www.google.com;font-src 'self' data: mikrotik.com fonts.gstatic.com www.mikrotik.com i.mt.lv;frame-ancestors 'self';
< Content-Type: text/html; charset=UTF-8
* Connection #0 to host mikrotik.com left intact
This issue seems to have started today around 9:40 UTC.
Thank you! Fixed.
Not sure if it’s a DNS issue from my side but ”mikrotik.com” works but not ”www.mikrotik.com
Thanks! It is now fixed for mikrotik.com.
But as @Larsa mentioned, there seems to be another issue with www.mikrotik.com.
$ host -t A mikrotik.com
mikrotik.com has address 159.148.172.205
$ host -t A www.mikrotik.com
www.mikrotik.com has address 159.147.172.205
It seems that someone mistyped the IP for www.mikrotik.com (159.147.172.205). I guess it should be the same as in mikrotik.com (159.148.172.205).
IPv6 is OK and working fine:
$ host -t AAAA mikrotik.com
mikrotik.com has IPv6 address 2a02:610:7501:2000::205
$ host -t AAAA www.mikrotik.com
www.mikrotik.com has IPv6 address 2a02:610:7501:2000::205
Fixed again, sorry :slight_smile:
