Mikrotik Command line ping bug
ping 192.168.34.1 size=1500 interval=00:00:05
worked
ping 192.168.34.1 size=1500 interval=00:00:00.2
do not worked
How is that a bug?
what?
you cannot set any lower time frame as 1 second in normal ping command.
if you need more pings sent - just use /tool flood-ping
Sorry for my simple expression. Ill try to explain what i have found.
Try write into RouterOs console:
[admin@GateWay] > ping 192.168.52.1 interval=05
You will receive this in 5second interval:
192.168.52.1 64 byte ping: ttl=63 time<1 ms
And than try to write into console this:
[admin@GateWay] > ping 192.168.52.1 interval=10
You will receive this message:
value of interval is out of range (00:00:00.010 .. 00:00:05)
Try to write into console this:
[admin@GateWay] > ping 192.168.52.1 interval=00:00:00.010
or only
[admin@GateWay] > ping 192.168.52.1 interval=0.010
You will receive this response:
invalid time value for argument interval
I think some think is wrong…
In winbox, you are able to do this. In console you are not.
00:00:00.010 is 10ms
you have to write
/ping 192.168.52.1 interval=10ms
And this is from manual:
interval (time: 10ms..5s; default: 1s) - delay between messages
so it is working as it should.
Ok THX for explaining.
But than it should be written this message by RouterOS
value of interval is out of range 10ms .. 5s)
instead of this message:
