Real-time spectral analyzer.
Propietary protocol ipoll.
2 firmwares in case of upgrade failure.
http://www.streakwave.com/Itemdesc.asp?ic=PROPELLER-5
this product is alternative to sxt lite, with the same price but with possibility of mode AP
It could be alternative if it would be much cheaper. Do not think it is as manageable as mikrotik. With mikrotik you have more than 2 possible system versions - see partitions.
I am thinking of competition in wireless…
But you can not take part from one device and part from another and make your dreamAP. You have to compare both devices as whole.
I am using mikrotiks as routers…ubnt mainly as wireless…now I started to use mikrotiks as aps(on ptm), not in ptp because of high nv2 latency…
so I can you for wireless what I want and also for routing what I want…not like you say whole:)
