If it work, is it possible to relay the DHCP service to the mikrotik, i am planning to give them a same address with the wired network because we dont have that many users.
If the access points are routerboards or other mikrotik products, you will just need to place the wireless interface on a bridge with the Ethernet port. and configure the wireless to your companies settings. remeber to assign the IP to the bridge and any routes the router should know.
Let me know if this isn’t clear or you cannot get it to work.
