Mikrotik connected to a unifi AP
I am trying to connect my mikrotik router to a ubiquiti AP, that has 2 wlans that I have defined as vlan100 and vlan200.
On the mikrotik router I have defined the vlan100 at the port ether2 and vlan200 at port ether3 with dhcp.
*Now I have an issue, I wanna make it so that port ether4 is where I connect the ubiquiti AP, so in theory I will need both vlans there (I think). Something I am not sure I setup right, since I donno how to test it.
This is the setup I have created:
Ether1
/interface set ether1 name="ether1-gateway";
/ip dhcp-client add interface=ether1-gateway disabled=no comment="default configuration";
/interface bridge add name=bridge-local disabled=no auto-mac=yes protocol-mode=rstp;
/ip address add address=192.168.88.1/24 interface=bridge-local comment="default configuration";
/ip pool add name="default-dhcp" ranges=192.168.88.10-192.168.88.254;
/ip dhcp-server add name=default address-pool="default-dhcp" interface=bridge-local lease-time=10m disabled=no;
/ip dhcp-server network add address=192.168.88.0/24 gateway=192.168.88.1 comment="default configuration";
/ip dns set allow-remote-requests=yes
/ip dns static add name=router address=192.168.88.1
/ip dns static add name=Google1 address=8.8.8.8
/ip dns static add name=Google2 address=8.8.4.4
/ip firewall nat add chain=srcnat out-interface=ether1-gateway action=masquerade comment="default configuration"
/ip neighbor discovery set [find name="ether1-gateway"] discover=no
Vlan100 and Vlan200 on ether2 and ether3:
/interface vlan add name=vlan100 interface=ether2 vlan-id=100
/interface vlan add name=vlan200 interface=ether3 vlan-id=200
/interface bridge add name=br-vlan100 disabled=no auto-mac=yes protocol-mode=rstp;
/interface bridge add name=br-vlan200 disabled=no auto-mac=yes protocol-mode=rstp;
/interface bridge port add bridge=br-vlan100 interface=ether2
/interface bridge port add bridge=br-vlan100 interface=vlan100
/interface bridge port add bridge=br-vlan200 interface=ether3
/interface bridge port add bridge=br-vlan200 interface=vlan200
/ip dhcp-client add interface=ether2 disabled=no comment="vlan100 configuration";
/ip dhcp-client add interface=ether3 disabled=no comment="vlan200 configuration";
/ip address add address=192.168.100.1/24 interface=br-vlan100 comment="vlan100 configuration";
/ip address add address=172.178.200.1/24 interface=br-vlan200 comment="vlan200 configuration";
/ip pool add name="vlan100-dhcp" ranges=192.168.100.1-192.168.100.254;
/ip pool add name="vlan200-dhcp" ranges=172.178.200.1-172.178.200.254;
/ip dhcp-server add name=dhcpVlan100 address-pool="vlan100-dhcp" interface=br-vlan100 lease-time=10m disabled=no;
/ip dhcp-server add name=dhcpVlan200 address-pool="vlan200-dhcp" interface=br-vlan200 lease-time=10m disabled=no;
/ip dhcp-server network add address=192.168.100.0/24 gateway=192.168.100.1 comment="vlan100 configuration";
/ip dhcp-server network add address=172.178.200.0/24 gateway=172.178.200.1 comment="vlan200 configuration";
Right now my issue is to find a way for vlan100 and vlan200 to be in ether4 aswell, and still have them in ether2 and ether3.
Nvm the second point have correct it, was missing the dns for each vlan.
Still trying to setup both vlans in one port.
Update on the situation:
So far I have setup both vlans on unifi AP, there is an internet connection on ether2(vlan100) and ether3(vlan200), both seem to work fine.
I am trying to get the ether4 working for both vlans, this is the configs I used to try to make it work:
/interface vlan add name=vlan100ether4 interface=ether4 vlan-id=100
/interface vlan add name=vlan200ether4 interface=ether4 vlan-id=200
/interface bridge port add bridge=br-vlan100 interface=vlan100ether4
/interface bridge port add bridge=br-vlan200 interface=vlan200ether4
/ip firewall nat add chain=srcnat out-interface=ether4 action=masquerade comment="vlans configuration"
/ip neighbor discovery set [find name="ether4"] discover=no
I dont have internet on ether4, due to that I cannot access the unifi controller that is online, so I can not be sure that the vlans are setup correctly on ether4.
