MikroTik - connections between 2 internal bridges
I have created 2 bridges internally bridge 1 from eth 1-4 where i work with 169.254.0.0/16 devices , and bridge 2 eth 5- 8 where i work with 172.16.0.0/16 devices… My problem is that i don’t know how to make the 2 LANs connected on the same microtik and make them see each other. Do i need to create a static route, form another bridge that includes both, work on the firewall, work on the NAT issue. I’m trying them all by try and fail, can you please help me with this issue ?
Please share your actual configuration. If you have IP addresses assigned correctly to the two bridges, and no firewall interfering, it should route between these two connected subnets. Do you have correct default gateways set on your end systems?
If you want full access between both, just make it one subnet LOL.
I would just use one bridge and two vlans myself.
