Greetings,
I try to access on internal service (webservice) outside the network (external access) without success.
I add this NAT rules
add chain=dstnat dst-port=8010 protocol=tcp action=dst-nat to-addresses=192.168.51.250 to-ports=8010
But when i try to access with my external IP on same port, error (connection timed out).
I have a specific setup :
Internet -> Router A with DHCP on 192.168.1.X -> Mikrotik with DHCP on 192.168.51.X
All my device is on 192.168.51.X network, all works (access to Internet, access to 192.168.1.X network).
On my Router A, i have a NAT rules :
- Wan port : 8010
- Lan Port : 8100
- Lan IP : Mikrotik IP on 192.168.1.X
I have this setup entry on Mikrotik (internal service is set on dhcp with static)
add admin-mac=04:F4:1C:8C:E7:6F auto-mac=no comment=defconf name=bridge
add name=WAN
add name=LAN
add name=dhcp ranges=192.168.51.10-192.168.51.254
add address-pool=dhcp interface=bridge name=dhcp1
add bridge=bridge comment=defconf disabled=yes interface=ether1
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge comment=defconf interface=ether9
add bridge=bridge comment=defconf interface=ether10
add bridge=bridge comment=defconf interface=ether11
add bridge=bridge comment=defconf interface=ether12
add bridge=bridge comment=defconf interface=ether13
add bridge=bridge comment=defconf interface=ether14
add bridge=bridge comment=defconf interface=ether15
add bridge=bridge comment=defconf interface=ether16
add bridge=bridge comment=defconf interface=ether17
add bridge=bridge comment=defconf interface=ether18
add bridge=bridge comment=defconf interface=ether19
add bridge=bridge comment=defconf interface=ether20
add bridge=bridge comment=defconf interface=ether21
add bridge=bridge comment=defconf interface=ether22
add bridge=bridge comment=defconf interface=ether23
add bridge=bridge comment=defconf interface=ether24
add bridge=bridge comment=defconf interface=sfp-sfpplus1
add bridge=bridge comment=defconf interface=sfp-sfpplus2
/ipv6 settings
set accept-router-advertisements=yes
add interface=ether1 list=WAN
add interface=bridge list=LAN
add address=192.168.51.1/24 interface=bridge network=192.168.51.0
/ip dhcp-client
add interface=ether1 name=client1
/ip dhcp-server lease
add address=192.168.51.252 comment="Test External access" mac-address=
BC:24:11:FA:8D:E1 server=dhcp1
add address=192.168.51.0/24 dns-server=192.168.51.251 domain=XXXXXX
gateway=192.168.51.1 netmask=24
set servers=::,::
add action=accept chain=input connection-state=established,related,untracked
add action=drop chain=input connection-state=invalid
add action=accept chain=input dst-address=127.0.0.1 in-interface=lo
src-address=127.0.0.1
add action=accept chain=input in-interface-list=LAN
add action=drop chain=input comment="drop all else" log=yes log-prefix=
drop_all_
add action=fasttrack-connection chain=forward connection-state=
established,related
add action=accept chain=forward connection-state=established,related,untracked
add action=accept chain=forward comment=internet in-interface-list=LAN
out-interface-list=WAN
add action=drop chain=forward comment="drop all else"
add action=dst-nat chain=dstnat dst-port=8010 protocol=tcp to-addresses=
192.168.51.252 to-ports=8010
add disabled=yes dst-address=0.0.0.0/0 gateway=192.168.1.254
/system clock
set time-zone-name=Europe/Paris
/system logging
add comment=firewall topics=firewall
/system routerboard settings
set enter-setup-on=delete-key
/tool mac-server
/tool mac-server mac-winbox
I think a filter rules is missing or block but i try to disable each drop entry, no success.
Thanks for your help !
