Mikrotik critical issue with I-devices
Few weeks ago I connected to new ISP. That’s why I decided to adjust wireless interface on router to speed-up.
Unluckily, I got issue with my iPhone. It always disconnects from Mikrotik. I found a lot of messages claiming identical issues between I-devices and Mikrotik. I tried to change “channel width” to 20 MHz, Band to “Only N” etc… Nothing helped!
It supposed to be a major issue for Mikrotik. Unfortunately, noone fixed It or found solution. Let’s find solution together. I got jailbreaked iPhone, so I can run tcpdump.
So, what I get every ~10 minutes:
iphone@wlan1: disconnected, received disassoc: sending station leaving (8)
iphone@wlan1: data from unknown device iphone, sent deauth
My config:
CCQ ~ more than 90
jan/02/1970 02:09:37 by RouterOS 6.22
software id = 82XR-9L9A
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=
20/40mhz-ht-above disabled=no distance=indoors frequency=2422 l2mtu=2290
mode=ap-bridge ssid=Global wds-default-bridge=bridge-local wds-mode=
dynamic wireless-protocol=802.11
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=
dynamic-keys wpa-pre-shared-key=password wpa2-pre-shared-key=password
jan/02/1970 02:19:20 by RouterOS 6.22
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=dynamic-keys
