I would like to know if it is possible to setup MikroTik crs109 – 8g-1s-2hnd-in as an basic DSL router without an additional modem?
When yes how is the procedure?
Thank you… in advance!
Cheers,
Alberto
Cheers,
Alberto
It is not.
The CRS109 is a switch primarily and has no DSL modem built in.
You would need a stand alone modem to demodulate and then you could potentially use the CRS109 as a router however I will warn you now, the performance won’t be brilliant as it is a switch with some L3 capabilities. Not a designated router.
Thank you… you can close this issue.
