Hi there,
I’ve recently bought a Mikrotik CRS125-24G-1S-2HnD routerboard. I’ve noticed that despite GE ports file transfer within my LAN is very slow. Maximum transfer I’ve seen was 300 mbps while average is around 150-200 mbps. Sometimes it’s under 60 mbps. I can’t find the reason for this.
I’ve tested that with my PC, two laptops and a banana pi board. Tried all the combinations and results are the same. Needless to say all those devices have GE network adapters.
Brief description of my configuration would be a home router with DHCP. All ports are currently bridged (I have also tried default configuration with slave ports- same effect).
RouterOS version is 6.27
Here is a result of a test suggested in another topic(pinging a laptop):
ping size=10000 interval=0.01 count=5000
sent=5000 received=4641 packet-loss=[b]7%[/b] min-rtt=0ms avg-rtt=0ms max-rtt=44ms
My friend has the very same routerboard also with ROS 6.27 and he says he can easily reach 700-900 mbps speeds in his lan.
Do you guys know what could be wrong? Is this a hardware issue?
